Originally Posted by extanker
i will take a stab. if it was my car i would hook up my 4 channel lab scope and monitor the batt,alt and ballast supply voltage and i would look for spikes while running . i would mainly look at alt and if pushed for a guess.....voltage regulator....if they are like the old bosch they are held on to the rear of the alt by 2 screws. like any electrical problem start at the source..the batt...is it old,low on water,connections tight etc ?
Thanks for the response. The battery has been drained several times. There is water in it though and all the connections are clean and tight. But I am guessing it might not be holding a charge like it should and causeing a strain on the system, what should the battery test at voltage wise when the car is off?
