The dampers I mentioned before are available for the Boxster and they do the job. I think they have them at Pelican Parts or PAP Parts. You pull the pads out, clean them well, slip the damper in the caliper piston, peel the backing off, slide the pad back in and press it against the exposed adhesive. Keeps it from shifting and squeeling.
