Old 11-13-2010, 11:46 PM   #1
BMAN_986
Sounds like a classic problem with the regulator. Porsche quoted me $600 to do mine, I did it myself for about $140. If you go down this to route make sure you disconnect the battery before you unplug the airbag and reconnect it after you have plugged it back in. If you don't do it this way you will get an airbag fail light which can only be switched off by a PST2.
Follow the regualtor changing instructions on pelican parts.
BMAN_986 is offline   Reply With Quote
