I would pull the oil sump plate to check for metal etc. in case your IMS bearing is dying & cut open your oil filter too. If everything looks good then I would buy a new set of good sparkplugs & install them while carefully inspecting the old plugs especially cyl. #1 & 4. Swap coils with connecters from #1 & 4 to a different position to see if they are faulty. Then start car & see if it needs anything else. Your AOS will tell you when you need to change it until then don't touch it. A new AOS may be worse than the one you have.
