passing this on- There is a new set of shocks and springs off the new spyder at plant-9.com for sale
This should lower the car apx 20mm. it is a stiffer set up.
I would also recommend the gt3 swaybar and tarret links for the front. most people run the bar at full soft, if you run it on a stiffer setting you will get push/understeer. Unless you can run a wider tire-255,265,max285 . good luck.
