I had the 'wiggle-the-harness' lock issue, appears it was just a matter of re-routing the wires to the lock mechanism. They were squashed between the door frame and that metal bracket that is bolted in by the three or four 10mm bolts. As soon as I un-squashed them and put them in a more sensible path, the problem seems to have gone!
Will keep the solder joint issue in mind though. Makes me laugh how so many of us are going through exactly the same strange problem though!
Sam
