Thread: Brembo brakes
Old 07-26-2005, 09:35 AM   #1
KevinC
The front S brakes will bolt right on. The rear brakes require more work because the eBrake is not compatible with the S rotors. Brembo makes specially machined S rotors which will work in a standard Boxster.
However, the rear brakes don't get worked very hard and don't really benefit from an upgrade. You might just want to repaint those and save yourself the hassle with the rotors. For that matter, the front brakes are pretty great as well. They are also Brembos. I had a '98 Boxster which I took to the track a lot. The brakes are really great.
KevinC is offline   Reply With Quote
