Are you still running the stock airbox? If you are then you need to check the fittings going to it. That second picture is one of atomized oil being vented to the atmosphere and then moved around by turbulant air under the car to land on the closest surface. It does not look like a dripping leak. I say simple green the area. Clean it up good. And then check it again in a few days. It will be easier to tell where your problem lies.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
