routing RCA cable from head unit to frunk
You have to move the battery to the side to see/access the unused grommet. Cut a slit with a knife in the gromment then push a straightened coat hangar thru the grommet, past the interior padding and it will exit near the pedal area. Tape the RCA cables to the coat hangar and pull them thru.
