coolant issue
need some advice on coolant leak. today i left the parking lot and the coolant light started flashing. i pulled over and checked for leaks...nothing to be found. i did see some moisture on some of the suspension parts so i know that liquid is leaking out. i also notice some moisture on the inside of the trunk lid just above the coolant filler cap. however, there was no liquid in the trunk. i got home and checked the level...i was about 2 pints low.
question is...does this look like a reservoir failure or do you think it might just be a cap or something else?
