Old 10-29-2010, 02:33 PM   #16
jmatta
I completely agree on shorter oil change intervals...4 to 5000 miles at the most/at least annually. In your climate, I would use a good quality 10W40 synthetic oil...30 weight is way too thin of base. If you drive in hot weather, 15W50 is a good choice.
Look into the LN IMS bearing upgrade...your engine (and wallet) will thank you. Also see if you have the original water pump...the impellers are plastic and don't last long and could ruin your engine should it break...cheap maintenance; replace the coolant with a fresh batch of OEM while you're at it.
Enjoy the car!
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
