					Originally Posted by Ckrikos
				 After reading the pelican article all it seems one needs to do is check the oil pan during each oil change. If you see metal get the car checked out. |
Once it gets to that point I think you are toast....or at least the motor needs to be torn down in addition to an IMS replacement.  Metal floating around in the motor = not good.
