Broken Litronic Internals
Hiya Gents, I recently purchased a pair of used '99 996 litronic assemblies and while they look perfect outside there is something wrong with the internals on both. The main projector is somewhat loose and bounces around inside when the whole headlight is given a shake and I could hear something loose inside. Pulling the rear covers off a small piece of plastic rolled out of each headlight. Can these be taken apart from the back to access the main projector unit and have the offending broken pieces glued back on or is it the end of these lights? Thanks!
