Originally Posted by Banana S
I'm not a fan of air conditioning, as I grew up in a house without it. Suffering through 90+ degree, 100% humidity, Indiana summers is no big deal to me. I actually like it hot. So I have completely removed the air conditioning systems from 2 of my prior cars (not Boxsters) in order to save weight.
HOWEVER... I would never do it again, for one simple reason: One day you, like me, will get caught in a downpour on a hot, muggy summer day. You won't be able to roll down your windows, lest the inside of your car gets soaked. And you will not be able to do a darn thing about the steam building up on the inside of your windshield, which will make it impossible for you to drive. So you'll be left, like I was, sitting in a parking lot in your own personal sauna until the rain ends.
Trust me, the weight savings isn't worth it.
Listen to this man. He knows of what he speaks. There is a good reason that car manufacturers put AC in our cars. And unless you are building a dedicated track car you will lower lap times at the track more significantly by changing tires than by removing some weight from the car.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
