RMS Failure: What is the cause?
The only thing I found with search was wobbling unsupported shaft. My VW 1.8T has just shy of 199,000(beetle is an MY00) on it with regular oil changes between 3000 and 6000 miles. And my RMS shows no sign of leakage. I truely believe that VW/Porsche know how to build or buy seals that work. So what is the problem with the RMS on the 986 motor and can it be fixed so that the seal will last 200,000. Does the seal ride on the end of the crankshaft? A little understanding please.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
