Just brought in my pristine guard red 97 from the USA into Canada a month ago. Unless the engine blows, I plan to do 95% of the repairs and maintenance myself.
So the car immediately grants me my wish. First off, the rear deck lid closed on some high cargo. That little ding you could see a mile away. Quote for repaint and blend came in at $450 - ouch! I carefully flattened the spike and then moved the boxster emblem up a few inches to cover the left over blemish. Completely invisible. Cost zero.
Then my Goldwing mirror punched into the L/S tail light assembly. Immediately put down $100 for a pair of good used lenses on ebay.
And now the power window. I started without a manual but read the many threads on this site. Starting off, if I thought I had shot, I would have taken pics - for sure next time.
The A pillar junction box is on the body between the door hinges. There is a torx bolt at the bottom surrounded by a plastic turret. A torx bit in a 1/4 inch drive hex holder will undo it. If not also use a 1/4 drive ratchet. There's not a lot of excess harness on the body side, but just enough to pull and wiggle as everthing separates.
Overall, I've been lucky so far.
