Its not internal. If it was you would have scattered the engine on the 2.5 hr trip home..
Probably a coil pack died or came unplugged and no the CEL won't illuminate in some of these instances. You also could have fouled a spark plug..
Wheel weights come into play when high wheel speeds are high, so if the issue happens in first gear above 4K RPM you can bet its not a wheel weight.
US Patent 8,992,089 &
US Patent 9,416,697
