I just bought a 2003 S and checked this filter. Two questions? Is the filter exposed or am I missing a top cover? I had to remove the battery cover and the cowling to the left. But then I could see the filter. It seemed like there should be another cover but am not sure.
Also, those little rubber stud on the fender that the torx screws into are snapped in half. I bet that is common but does anyone have a part number? I spent the weekend searching but came up empty.
Thanks,
Tom
Originally Posted by BadBoyS
Filter is in the Front compartment. Under the plastic cover. Passenger side. First remove battery cover (plastic) then remove the cover infront of the passenger side).
Filters the interior air.
Very easy to replace just pull it out and put the new one in.
Good luck
