Originally Posted by sd_boxster
I took mine apart (i.e. I removed the plastic insert with the mirror, light, etc. from the rest of the visor) to paint over the warning labels with black spray paint. Turns out that the solvent in the spray paint completely dissolved the labels, so I used a microfiber towel to wipe off the first coat of paint and the label remains, gave each side a proper coat of black paint, and am delighted with the results.
Hi sd_boxster,
You did exactly what I was doing and had the same result.. the paint I used on my '04 986 550 Spyder Edition visors years ago made the decal wrinkle up. I took some alcohol in desperation to remove the goo, knowing that it wouldn't hurt the vinyl. Then after I had the mess cleaned up....... I just used it to remove what was left. On the passenger side visor I started and ended with pure 91% rubbing alcohol. Took a bit of rubbing but they are GONE!
Cheers,
J Tinsby
