Originally Posted by jaykay
Thanks I didn't know they were the same dampers. That is good news. I am concerned with fit in spring seats; available damper stroke with the lower H and R springs; mis match between the spring rate of the H and R springs a the M030 dampers. I definitely knew about the rear toe-in on bump that could require some after market adjustables (any favourites?) to get the wheels pointing neutral again. I thought one could get camber with the stock eccentrics.
How are these people finding the ride of this set up? Just a stock S on 18s can be harsh on certain roads.
I am still running my stock suspension on my 03 S so I really cant answer your questions with any certainty as far as spring rates, ride quality and damper stroke. I think I have been trying to figure out the same things you are. I only want to replace my suspension once and I need something that fits my daily driving needs without being overly harsh or screwing something up that would require more parts. One thing I can tell you is that a lot of people have been using the adjustable toe control arms from Tarett. They seem to be a quality product.
http://www.tarett.com/items/boxster~cayman-products/996-986-987-rear-t-control-arm-pr-996tlnk-detail.htm
When it comes down to it, I think that for my needs and for the money I am willing to spend, the ROW suspension is probably best. I don't want to spend a ton of money on all these extra suspension parts to maintain alignment and then have my daily driver ride like crap. I started another thread last week asking questions about the ROW kit but haven't gotten any responses.
Rear suspension problem and the ROW M030 European suspension as a solution
