			When I do a certified pre owned engine, I prefer the entire vehicle.. Thats because I want to install the engine here and I want to test it on the chassis dyno. I also want to throw my data logger in the car and test the engine to and from my house for a couple of days before release.
The cost associated with this isn't much more than shipping engines to and from the facilities, since we do require a "core" with the Certified engines. Generally shipping the entire car runs less than shipping the engines both ways! This way we also can provide specialized installation and test work to KNOW the engine is solid before shipping. This is especially critical because its a used engine and has no warranty, I won't warranty Porsche's engine, only those built completely here at my facility and completely updated.
The going rates for a certified pre owned engine is generally 7-10K, with that we do the following:
-Update the IMS bearing with the LN/ FSI unit
-Replace the water pump
-Replace lifters with FSI updated units
-Replace chain guides and vario-cam wear pads
-Replace clutch assembly
-Replace AOS
-Replace RMS with 997 unit
-4th and 5th timing chains replaced
-Install new LN Engineering lo temp thermostat
-Install LN Engineering Spin On Oil Filter Adaptor (SPOFA)
This program is proving to be very successful and is giving those who can't spend 18-22K on our fully updated engine a way to take advantage of our special services and a few of our parts without killing the bank account.
Yes, these prices are still more than the "rebuilds" of the mass producers, but if you compare notes you'll see that they don't even replace the AOS or lifters in their full rebuild, but we do these things to a "used" engine because they are simply required.
No, this engine doesn't come with the warranty or pedigree of a fully built FSI updated engine, but it is updated as much as possible under the same roof.
Pat,
I'll keep you updated when the car arrives and etc.. If its ok with you we'll use this thread as a way to communicate so people can see first hand what is associated with the aftermath of an engine failure. I'll post all the pics here and updates to the project as they become available.
As soon as the car arrives I'll take some pics and find it a stall in my stable until we can tear into it at the beginning of the coming week!
(Pat is a great sport, he was still witty even after experiencing what looks to be a full blown failure, most people act like their dog just got shot, for good reason)
US Patent 8,992,089 &
US Patent 9,416,697
