The IPD ...
... and the similar TechnoTorque should not generate a CEL when installed correctly.
You probably have a vacuum leak from a misaligned rubber connector (usually on the bottom where it's not obvious).
There are also vacuum lines and a vacuum check valve that connect to the rubber pieces that sometimes get overlooked.
Recheck all of your work.
Once you find the leak, correct it, the reset the CEL.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
