Old 10-08-2010, 04:31 AM   #11
greenerob
Originally Posted by tuanle16
greenerob,
thanks. when i posted, i didn't see yours. sorry. newbie. as for the bit, couldn't find it at home depot. that was the only one that was long enough. i'll try a different home depot. not much selection at local one. were you able to drill with cordless drill or did you have to get a corded drill? electric ones have more power right? also, instead of crios recommendation of drilling towards midline, you punch your hole away from midline, right? will try again.
I drilled with a cordless drill. It probably took a little longer though. As far as the angle of the I held the screw drivfer as far towards the center as the tips would allow and then waked it a couple times. I used a long and thick flat headed screw driver.
greenerob is offline   Reply With Quote
