Old 10-07-2010, 06:34 AM   #2
yelojkt
Originally Posted by jcb986
Did you purchase original or a OEM replacement.
This was what I was wondering.
I have put two clutches in my Beetle. The first time I traded out the dual-mass spongy flywheel and put in a lightened G60 flywheel with a sachs pressure plate and disc. The pedal pressure felt a little easier. The second time I replaced the disc and the throw out bearing and when I put it back togather the pedal pressure was very light. That seemed strange, I figured something was wrong but I have put over 40,000 miles on the second set-up including track time at Hallett. Go figure.
What parts did you change out?
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
yelojkt is offline   Reply With Quote
