Old 10-07-2010, 12:27 AM   #1
Bruce Wayne
Bruce Wayne's Avatar
it looks fairly clean, there doesnt seem to much peppering of the nose from the ubiquitous stone chips, so check for any overspray and that if it has been painted on the front (not unusual - here in the UK, it's getting on for normal practices for dealers to paint the front bumper before putting it on the forecourt). also the rotors look, from the picture to be a little bit scored. no biggie, but bear in mind they may need doing.
also the wind deflector and baffles behind the seats are not in the picture, if the mounts are there for the center defelctor, you may want to replace it, or if it doesnt bother you, you may not.
tough to tell from the pics but it 'looks' straight and if the car fax reports check out ok, i'd put it in the mix for consideration for sure.
the point to remember 'caveat emptor'
good luck and let us know ..
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
