i am having the same problem as some others. can't get the angle because of the welded tip. the bit just slides down the pipe. any other suggestions. also, looking at the original picture...am i suppose to drill through two pipes? ie.obviously, drill a hole into the last out going pipe, but then does that hole just enter into the chamber? or is it suppose to enter the entering pipe? refer to the original picture. the "bypass" as outline on the picture with green arrow, shows pipe1 to pipe2. thanks. is there a specific drill bit i should buy? i bought one that was extra long and "masonite" bit, but it didn't work.
