Old 10-06-2010, 08:01 AM   #11
greenerob
Crios Exhauset Hack to 1998 Base with Welded Tips
Just did this hack to my 1998 Boxster Base. I of course have the welded tips.
I took a long screw driver.
Angled it as much as possible towards the outside of the car so that the tip was on the inside of the pipes.
I held the angle as hard as I could so it wouldn't slip inside the pipe.
I hit it with a hammer a few times to create a hole.
I drilled the hole until it was all the way through being careful to not go any further inside then a complete hole.
The sound is noticably throatier at low RPMs, but there is no difference at the higher RPMs probably due to the much higher flow.
Recommended and easy.
greenerob is offline   Reply With Quote
