Crios Exhauset Hack to 1998 Base with Welded Tips
Just did this hack to my 1998 Boxster Base. I of course have the welded tips.
I took a long screw driver.
Angled it as much as possible towards the outside of the car so that the tip was on the inside of the pipes.
I held the angle as hard as I could so it wouldn't slip inside the pipe.
I hit it with a hammer a few times to create a hole.
I drilled the hole until it was all the way through being careful to not go any further inside then a complete hole.
The sound is noticably throatier at low RPMs, but there is no difference at the higher RPMs probably due to the much higher flow.
Recommended and easy.
