Originally Posted by greenerob
I have already replaced the headunit. The dash and door speakers are on the way. I also added speaker to the rear storage.
I just want to replace the factory amp with a higher powered one that I already have. You mention a rewiring adapter on ebay. I can't seem to find one. the ones I see are the same as the one I used for the headunit install.
Aww.. I guess your right.. Wiring connectors are available for Radio, not really for the Amp.. if you REALLY don't want to touch the original wires of your car you can still buy a cheap AMP and take the connector out of it and work this out, other case I guess you'll be stock cutting out the connectors.. if you do so keep the connector with enough wiring lenght to restore your system back if you ever need to (or next owner)
