Old 09-28-2010, 03:11 PM   #12
chaudanova
Thumbs up
Originally Posted by AndyA6
I followed your post on 6speed, thanks for posting here!
I just wonder how this setup would compare to a Technotorque and the "homemade" intake hose, of course with the same throttle body..........
In my opinion, I don't think there is a comparison at all. One makes power and one loses power.
The TT (in theory) seems like it would work, with the splitter design in mind. Problem is, that it is still too small, using the stock sized T-pipe, and then is made even smaller by putting the splitter in there, decreasing the inner volume.
The IPD plenum is an entirely crafted out piece, and not only is larger, but has much more into the R&D for improved airflow.
There was a (controversial) thread in the forums where the Technotorque lost power, dyno backed.
On the flipside, almost every single dyno chart I've seen with the IPD proved real power gains...
I'm no racecar engineer... these are my thoughts on this though...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
