Old 09-28-2010, 12:27 PM   #2
Perfectlap
Perfectlap's Avatar
it's about a six hour job if you are taking your time. Two hour to pull out the transmission, two hours to extract the old bearing and replace it with the new LN engineering unit, two hours to put all back together, put in new engine oil, check everything.
My non-dealer Porsche speicalist charges about $90 an hour for labor. So for a IMS upgrade it will be about $540 on labor and another $600 in parts, or $1200 total with tax. Any Porsche specialist can do this job it's pretty straightforward. Some guys have even done it by themselves without a lift working in their garage for a few days. Since you're going to pay for six hours of labor most people change the clutch ($600) and maybe replace the axle boots (at least 2 hours labor) which are often torn on high mileage cars. I did all of the above and also decided to play it safe by replacing the flywheel ($600), the old flywheel had burns on it from waiting too long to change the clutch.
Check with your local Porsche Club maybe there is an independent specialist they all use. Surely he's done this job by now.
p.s.
$1200 for an IMS is not a lot of money if you put if you happen to be the unlucky one in a 50 or 100 that has to go looking for a $10,000 engine.
BORN: March 2000 - FINLAND
