Old 09-28-2010, 09:01 AM   #2
Kirk
I'd look on eBay or a dismantler for the fascia piece that you want. You could probably also get one direct from Porsche. Do a search on here though for "MOST" and you'll see you have other hurdles to overcome with changing the headunit on an '04 Boxster. They use an optical system for data transfer (communication with the amplifier). So you need to either change out the headunit along with the amp, or utilize the amp in the headunit, but using the OEM amp will not be a cost effective option (there are some spendy connection options) with an aftermarket headunit.
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
