Thread: Bump Steer
Old 09-26-2010, 10:54 AM   #6
Frank M
Originally Posted by JDBOXSTER
The feedback thru the steering wheel is a quick minor steering wheel pull when engaging a bump in the road. Car has brand new Conti Sport tires , stock sway bar.
Alignment performed recently and no problems found.
Could it be the rack?
JD BOXSTER
I have had control arm bushings do this as well as the valving in the rack becoming overly sensitive.
My first choice would be contol arm bushings, rack bushings if it has them, then the rack itself. I would carefully verify the rack valving is off by making slight adjustments on the steering wheel while at speed and notice the response. I would look for an over reaction in steering will little steering wheel adjusting.
You didn't specify but I assume, the new tires was to correct this problem heh.
NH
Frank M is offline   Reply With Quote
