Originally Posted by jcb986
I believe the consensus is that these metal ones are not recommended. The plastic ones are designed to be a weak point, and to break when there is some sort of an obstruction or problem. The plastic is cheap and easy to replace (relatively speaking), versus everything else down the line that could break instead, when there is an error in opening/closing the top.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
