Old 09-21-2010, 02:26 PM   #10
Burg Boxster
Originally Posted by jaykay
Has anyone powered the door latches via the cigarette lighter socket with battery removed?
yes, I think people have but you have a '00 which has manual levers to open the trunks so it's a different issue. Yours has a slide plate under the levers which is locking you out. See this thread for easy solution...
Just Follow the Directions in This Post
FWIW, w/o a battery installed, do you know where/if the cables might be touching each other or the body? I'd be hesitant to apply any power w/o knowing......
Good luck
