Originally Posted by eightsandaces
Did you manually spin and inspect every wheel? I'm not thinking it's the pads, I'm jumping on the bearing bandwagon, it might be silent in the air because there is no load on the bearings.
I span each of the fronts, checked for movement of the hub etc, wasn't any noise apart from a very slight grainy sound (which I believe to be the brakes).
Is it possible to replace bearings DIY?
