Old 07-18-2005, 08:39 AM   #5
deliriousga
deliriousga's Avatar
I used the Bosch Platinum +4. Since that is what the dealer used the first time they were changed, I figured those were stock. They have been great and one of the forums Tool Pants listed confirms the dealer uses both Beru and Bosch.
Be careful messing around with it, though. Porsches are picky. The 928 was made to use a specific copper plug and does not run as well on the platinums and can be damaged by them, no matter how expensive. Personally, I'd stick with stock.
EDIT: Make sure you're using the right heat range plug and not just the +4 you can pick up at Auto Zone.
1966 Wife White/Brown Top
