I experience creaking/groaning from my lower control arm (the one with the ball joint) and I've replaced one side three times now and the other side once up front. These go out frequently on our cars.
Fill the power steering reservoir and then see if the creaking still exists, if it does I'm confident you have a worn lower control arm. If you remove it and the ball joint flops around and grinds with aluminum on steel, you know you found the culprit.
