Old 09-19-2010, 10:11 PM   #2
chaudanova
I believe the modifications for the 986 fitment (compared to stock for the Cayman application) is this larger nipple, and machined back piece.
Here is a comparison of the stock boxster 69mm throttle body next to the upgraded 75mm throttle body. (For simplicity sake, I'll refer to these as 69mm and 75mm, although the actual dimensions measured accurately are more along the lines of 68.xx mm and 74.xx mm). The larger "75mm" throttle body comes on the NA 996 Carreras, 987 Boxster & Cayman, 997TT, 997 NA, etc.
OEM T-pipe removed and new IPD silicone reducers set on the oem intake manifolds.
"Modified" Cayman S IPD silicone hose (cayman hose coupled to another hose via tube for temporary setup)
More to come...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
