Old 09-19-2010, 03:15 PM   #2
E9project
reply about key
Originally Posted by jwade
Did you leave the key in the ignition before you did this? Could you get the key out of the ignition after your last switch went bad?
The key needs to be out of the ignition prior to replacing the switch.
The key goes in and out without any problem. The instructions I've seen say to turn the key to the on position to remove the tumbler. That the position rest of the assembly is stuck, so I think the tumbler will remove like Bentley says.
How do you like the ROW MO30 package? I do little Autocrossing with mine and have thought about this upgrade. My car would also look better if it were a little lower. Does this ROW lower the car too?
E9project is offline   Reply With Quote
