I forgot to add, in response to your other questions... It's a fairly simple fix (assuming this was the problem)... I have no idea what the dealership would charge you to fix it, but the dealership rates are usually pretty expensive, regardless of how easy things are.
You could get some replacement ball caps and replace them yourself fairly easily.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
