Thread: Tiptronics
Old 09-18-2010, 06:55 AM   #10
Lil bastard
Lil bastard's Avatar
Originally Posted by DerrickCaracter
is it possible/expensive to convert a manual into a tiptronic?
All things are possible.
But, in this case, it's gonna be $$$.
First, you need the box and differential.
Then you need the TipS shifter, Steering wheel, Ignition interlock, Brake pedal, new Instrument cluster and interior bits.
Then, a new DME, wiring harness, relays and a few engine sensors.
Then new cooling bits, incl. trans cooler and valve.
Finally, you'd need to remove the clutch hydraulics, pedal, and probably do some welding to the floor.
All said and done, it'd be waay easier, and cheaper, if you have a manual Boxster to sell it and buy a TipS Boxster. You'd likely even end up with a little change in your pocket too.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
