Thread: Coolant Dump
Old 09-17-2010, 10:48 AM   #5
sheep
Thnx folks for replying , today i stripped the boot out and found the middle hose had white residue all over the top of the hose , so i took it off checked for splits and put a new clamp on both ends re-filled the system just with distilled water and left the air bleed clip in the upright position.
I then connected it to my laptop and ran the software i have to check the temp etc etc , it was running at mid 80's the inlet temp was 30 , after a while it crept to 91 and the fans both sides kicked in.
I left it run a while more and then shut her off and underneath i had a few small drips certainly not the dump i had before and again the drips were cold water , so i now await my new cap and then i will redo all the tests again.
The fluid level was at the max and after running for a while with the cap off i was checking for bubbling etc as soon as i put the cap on the level rose out of sight after cooling after switch off it returned to the max mark.
Boxster 3.2s 2000 Artic Silver
sheep is offline   Reply With Quote
