Old 09-16-2010, 02:15 PM   #10
Jaxonalden
Jaxonalden's Avatar
Originally Posted by blue2000s
It takes 12 seconds for the top to go up or down, I don't see the point. Convince me.
Okay,
The idea behind this is to do it on the run, that by the way is the only time you can use the one touch feature is to be moving at the time to active it-fwd or rev. If you’re stopped you have to hold the activation switch down (safety I guess). You also don't have to have the emergency brake engaged because it overrides this safety feature.
So let’s recap; No more E-brake, no more being stopped, no more holding down the button.
BTW, if you do have a bind in your top and you continue to activate the switch the first thing that will brake is the plastic socket of the ball & socket of the drive motor arm. It's made that way too protect the rest of the mechanism and they cost about a $50 for one arm...less at a salvage yard and easy to replace. I know because I’ve done it twice. Once because my wife didn’t unlock the top all the way and the second because neither did I.
