Old 09-15-2010, 02:59 PM   #1
Cloudsurfer
Being a 5 chain motor, you SHOULD be ok pulling the tensioners with the crank at TDC without locking the cams, but I'd emphasize "should" in that sentence. I've had a cam slip a tooth on a 3 chain motor when a tensioner was pulled, and had to go back and re-time the engine.
Boxster S
