Old 09-14-2010, 03:35 PM   #1
autodoctor911
dme chassis relations
Is it not possible to get by without the functions that the dme needs to talk to other modules for. all I want my ABS to do is keep the brakes from locking up.
if the lights are on for abs, but it still does that, I don't care. can the siemens dme not be programmed to do the bare minimum to run the engine, and ignore everything else?
I certainly would want to at least eliminate AIR and catalyst monitoring. why not eliminate the functions that relate to the other modules? I am not going to be running a tiptronic or a PDK.
bty what do the pro racers use for a dme in gt3 racing? they have no abs, or any other modules on board, related to a street car.
in fact, isn't there a GT3 production model with no ABS? COUld you not use the stock programming for that dme as a starting point?
autodoctor911 is offline   Reply With Quote
