Old 09-13-2010, 08:24 PM   #4
ChrisZang
ChrisZang's Avatar
Originally Posted by ekam
With them installed you will not be able to remove your pads while your caliper is still attached to the hub. Because of this, none of the track/auto-x guys use them either as they swap to track pads on the track.
True !
The Weltmeister Anti-Squeal liners/stickers work reasonably well
However they tend to delaminate when the brakes get very hot on the track (and only on the track, so don't worry as long as you are only doing spirited driving), as long as the Porsche lettering on your calipers stays white and does not turn yellow they're fine
