Old 09-12-2010, 06:39 AM   #5
ppbon
ppbon's Avatar
As others have said...
... first replace the front engine mount.
You may be somewhat used to the sounds a front mount make as it starts to crack, but as it worsens with time it starts generating new noises, especially if the center core wears down to bare metal.
Your CVJs will also add to the noise as more tension is applied to one side.
Don't wait any longer. You can do expensive damage if the engine mount is left damaged.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
