In the middle of a motor mount swap and I thought I did my homework but...
Anyone know the correct torque specs for the motor mount nuts and bolts? I was going by Pedros DIY instructions which says everything is 34 ft-lbs but that seems a little light, especially for the connection between the yoke and the mount. Another post on this forum says 48 ft-lbs for this and the yoke to the frame with 34 ft-lbs for the mount to the engine. When I took things apart, it sure "felt" like things were tighter than 34 ft-lbs.
I don't want to over torque things but then again, I don't want pieces falling off later on. I guess for now, I'll do the two yoke bolts at 48 since you can't get at them once installed. The others I'll do 34 and tighten them up later if necessary.
Glen
