what was the inner diameter of the 996 and 540i Maf housing? Can you tell me the OD also?
Would there be any advantage to using a 996/540i larger housing with the regular 986 maf sensor if connected to a cone filter on one end, and, for my current setup to a larger 3" through hose/pipe with 75mm TB and IPD plenum?
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
